Thanks for the info guys, it helps. A couple of questions.... #1, why the 4:1 applicator? Is that the rate the glue comes out of the gun? The mixture is 1:1 correct, as determined by the side by side attached tubes?
#2, is the glass beads really needed for my running board application?
I'm starting to question the cost and the benefit for this project.
Thanks
Lord's 406/19 must be dispensed at a ratio of 4 to 1 for it setup properly. No the glass beads aren't necessary - I didn't use them but they also couldn't hurt either. Check out this post for the items I used during the install of AirFrame boards on my '09 RMK 155". Now Better Boards or other similar boards may require more 406/19 than I needed, just an FYI.
http://www.snowestonline.com/forum/showpost.php?p=2753293&postcount=80
Also, the applicator is what pushes, controlled buy the trigger - think of a caulking gun here, the adhesive & catalyst into & through the mixing tube and then on to the surface(s) being bonded. I high reccomend buying extra mixing tubes regardless of the amount of adhesive you buy.
