Pro RMK parts that will fit the Axys?
QD belt is new, longer, and different materials again, I believe. Drive belt is new.
Poo might make as much on spare belts as the entire sled.
Word I heard is that they added a tooth to the top pulley and knocked some off the bottom pulley in order to get the length. Gearing suffers but with a 7 tooth driver it helps. More contact on that top pulley is a good thing.
With the smaller drivers, the final gear ratio is actually lower than the pro. IIRC it was 2.32 and the pro was like 2.01 (Please don't hold me to those numbers)
ICR has it right...
The front ski shocks will bolt on from the PRO-Ride to the Axys.
I heard from a very reliable source yesterday that even the rear track shock from a Pro might work on the Axys. The shock length difference is only 1/4". I hope that is factual. It will save me money if it is. I have revalved W/E shocks on my Pro that I want to put on the Axys. I also already have the heavier spring on my rear track shock. If it will work, that is what I will use. If not, at least the other 3 shocks will work so I will only have to have the rear one revalved.
