Quote:
Besides any unburned fuel present in the exhaust, as in the scenario you present, would immediately be detected by the wideband as an increased lean condition.
you mean "rich" conditon correct???? A.
Nope, a lean condition because the O2 Measures O2, not fueling...
Man, Talk about a loaded question!
To be honest that would depend on so many variables that I could not begin to give an estimate on BSFC vs time at specific load/ RPM.
All I could do is give a base comparative as it relates to many various operating conditions and engine dynamics.
One way to look at it though, providing many variables were taken into account such as RPM threshold for sustainable engine durability, if the pre-known causes for engine detruction that are heat related then failures from those cuases would then be eliminated.
I hope that is close enough to satisfy yuor question.
....Sounds like a Obama answer![]()
Did you not say this is more efficient(better energy conversion)? I gathered "it is" from all the jargon. I'm curious if you could use two BSFC comparisons as reference points to contrast a "traditional setup" and your setup in similar "state of tune"....
Also please expound on "energy conversion" for this context if I'm missing it. I think you are saying you get more of the GEU converted to torque but I'm not sure I follow completely........ watts are watts, joules are joules.
Confused on MN![]()
No offense taken. I'll freely admit to taking something of a "devil's advocate" point of view. I don't expect to be spoon-fed anything, but I'm trying to find out how much YOU know by watching whether your explanations are addressing a topic directly or talking around it. I've heard plenty of sales pitches and promises over the years ranging from almost believable to totally ridiculous. To be honest, some of your posts earlier sound too much like sales pitches with just enough "technical" in them to sound good. Your recognition that the engine is a complicated system does give me some hope that you actually DO have a clue. So, keep posting, I'll be reading. Just remember, there are a lots of people here who have a lifetime of 2-stroke experience behind them - people who have built their own motors, pipes, heads, etc. You may learn some things from us, just as we may learn from you.It looks like you live close to me and if it is close enough I invite you to come and check out what I am doing, maybe we can go for a ride...We got snow now!
I appreciate your input so I am going to be as patient and as brief as possible. If you take what I have to say to heart then so be it, if not, I can only say you need to learn a little more before making blanket statements. It only identifies that you do not fully understand what energy conversion is all about and how it truly effects engine power output. That being said I can tell your concepts in thinking, as related to engine heat, are based on a skewed view ofconvention with little in the way of understanding of what proper fundamental engine dynamics are and can do. That is not a slam, just an observation. Go back and re-read what I have written thus far.
I fully understand the function and incompassing importance of a tuned pipe. Pipes are important yes. They are however one piece of a very extensive puzzle. If you have a puzzle with a say 20 pieces and some are bigger than others, when you have all the big ones, and parts of others, in the proper place you can still tell what the picture is... Understand?
Maximum cylinder filling is effected by a "perfect pipe". But you need to first identify what is "perfect" and what is not. Perfect to one person could be a pipe that produces a broad useable owerband over a wide RPM yet not making as much peak power. Others may view it as producing a maximum power yet narrow powerband. There are also other criteria in this "perfect" scenario all too imprtantly overlooked. There is not a "perfect" pipe made for a sled chassis, in relation to proper flow dynamics and sound wave distortion, in the US that I have come accross. Close maybe, but no where near perfect. I do not need to explain myself here, it would simply take too long. It just needs to be taken at face value. ANd NO I have not tested every pipe there is. But I can still look at a Dog and tell its a Dog whether it barks or not...
I asked "what if" a certain compression ratio was possible. Not that poeple need to run it to get the power they require. People pull start 14.5:1 engines and that compression ratio is more than enough, with proper engine dynamics, to put any stock engine into pieces. People can also buy starter kits, and they do.
If there is a particular statement you have a question on then I will be glad to address it. I want to educate people here but I am not going to spoon feed people who have a set ideal on what they percieve as correct. Especially when they do not want look at things as they really are. I hope you want to learn and not think I am just being a D.H. because that is not my intention![]()
And before I forget, yes I do know where Siren is - I've ridden in the area some years ago. I'm just a couple hours SE.
If you could keep better control of the scavenge and piston motion induced flow, where and how it flows in the combustion chamber you can and will achieve lower cyclic variation in the combustion process as you will present a more even condition at the spark plug for each cycle.
A low cyclic variation would allow you to use higher than "normal" compression ratios without hitting deto. just because you now do not have certain cycles with extreme time, temperature and pressure in the chamber.
I know that combustion chamber shape has a huge influence on this very matter and if you have found a chamber design which puts this in a better position than todays best designs it s wonderful.
The question is simply what your way around the problem is?
I remeber this being posted about a year ago...
The ONLY way anyone will be convinced is if it is proven in side by side comparisons and dyno results in real applications.....all the theory and speculation in the world is....well.....just theory and speculation.![]()
Maching some heads, throw them on a couple different sleds, post the results and people will listen.
After all the different designs that have been tried, all the race teams with some very smart guys and big $$ budgets, all the "snake oil" that comes and goes, it is only natural for people to be skeptical. I wish you luck and look forward to hearing some good results in a real-world application.![]()
I can see where VE or cylender filling would be effected by reversion.
I can also understand how a open chamber head desing would be effected by reversion.
my question is, reversion is caused by port timing and sound pulses in the pipe
isn't it?
I dont claim to understand all of this, but i think i understand where you are going with this.
and i doo have a cabed 800 skidoo, if you still need people to try this out.
THE most detonation-resistant head design in existence is the toroid, which became doubly important in 125/250/500cc motorcycle GP racing in the late '90s following the introduction of unleaded fuel. Naturally, only the most det-resistant design would do. And to this day, the combination of flat-top pistons and toroid domes is used on ALL GP racers. This is state-of-the-art:
http://www.twostrokeshop.com/two_stroke_shop_engines.htm#headinserts
We at TSS would welcome some back-to-back tests with any other type of head insert design. Bring it on.
Enough of the empty 'tell'. Let's see some Show and Tell.
Cheers,
Steve
you are not posting anything usefull in the conversation.
