If Poo's should have a coupon for Better Boards, then the eTecs should have a coupon for piston rings and clutching kits.
Mine used less oil then the other 3 sleds in our group, I haven't premixed, I'm just riding the sled since there is 3 years of warranty left. I asked My dealer about turning the oil pump up a bit? They recommended not to, because Polaris has a set Air Fuel Ratio (AFR) In the engine computer. Changing the oil ratio will change the AFR and the sled wont run to is optimum performance.
Blanket statements about sleds can be somewhat credible, but I bet if one were to collect all info about all sleds of a brand/model, blown up and running, you would see a trend. Quality of oil, warmup time, usage, etc all play in the equation. If a guy bought a new sled that was clutched for altitude, rode it out the door without warming it up, using Penzoil 2 stroke oil and screaming down an icy trail at 9500 rpm at sea level, I bet he could blow it up.
The 02 Skidoo 800 engines had piston/cyl clearance problems, we had to replace a ton of pistons under warranty. But some just clattered away and never broke a skirt, others did. Our demo never broke, but it was ridden by people who took care of it. Polaris cranks seemed to go out a lot in the early 2000's. If an engine has a "weak" spot, it will be highlighted by misuse or less than perfect conditions. Not saying anything about anyone or any sled, but there are many factors.
I buy and part a lot of sleds, I bought an 03 RMK (brand doesn't matter) that had 3400 miles on it when the crank broke. (Also doesn't matter.) Looking at it, I would have guessed the sled had well under 1000 miles, it was perfect. I am now looking at another sled that has a little over 700 miles total, I would guess that it has 4000-5000 miles in it, just in how it was taken care of and maintained.
Geez, I must be bored..................![]()
1200 trouble free miles on my ProRMK! Love it!![/QUOTE
Waiting on snow? You should be here.
hey all you guys adding oil to the tank.. why don't you just turn the pump up a little.. check the marks and set just a bit rich.. lots of Polaris sleds at our house.. have had all the bad ones too 08, 09, 10, 11 & 12.. skipping 13 to see how the new drive pans out............anyway.. they are all set way lean from the factory.. probably for emissions nonsense.. measure your oil and adjust the pump..your machine will be fine... throw the stock muffler too.. they all have to much back pressure to scavenge exhaust for emissions.....![]()
Nice! Just snowchecked a 2012. Looks like i will let the dealer keep it. Anyone got a good price on a 2012 cat? 10,500 out the door....... Tax included takes my 2012 orange 163 if anyone wants it. Lol!
Being impartial, the clutching has been very good on the etecs.![]()
