100% Agree! Heat will always travel from hottest to coolest point until all temps are equal. Eg gas compressor cylinder temps 325c, coolant leaving cylinder 75c. Engine shuts down, after a couple min at jacket water temp rises to 90c. High temp shut down rings in. Jacket water continues to warm to 120c. Cylinder temp still at 280c so jacket water temp will continue to rise. Unit starts up, trends back to normal with no big swing in cylinder temp. And a 2500hp 2 stroke v8 gas compressor has much larger jacket water coolers that hold much larger volumes. And I can trend every temp every second during start up or shut down. Bit of a odd comparison but the same idea.
Excellent info!! Thanks for sharing REAL DATA from your experience... 2500 HP will surely create some serious heat....
The coolant can only take heat from the components it is in direct contact with.. So, when people say the "engine" I think the piston,head, cylinder and crank train..
The coolant is ONLY in contact with the cylinder (outside), head (outside) and a very small part of the upper case...
It is never in contact with the piston or crank train which are the components (you need to be concerned with) that are doing the majority of the expansion and contraction..
It may be that it is not clear the transfer of energy???
The coolant is NOT cooling it is actually being
HEATED!!
The engine's components are ALWAYS
HEATING the coolant..
the coolant is not cooling the engine components...
As these engine parts
HEAT the coolant, they give off heat energy and cool down BUT the transfer of energy is from HOT to COLD and the coolant will NEVER be hotter than the engine.
Correct me if I am mistaken, but it seems that general concensus is that the coolant is cooling the engine via dominance (for lack of a better word)? and this is the basis behind this "Cold Shot".
The Heat source will always be dominant and unless it is totally over-whelmed with a colder media (which in this case it is not) it will remain dominant.
I tried to explain this somewhat in this tech article located -->>>
http://www.2strokeheads.com/COLD SEIZE.htm
Please, if I am mistaken and I misunderstood all those Physics classes I took in College, correct me. I am sure there are other Engineers on this forum who can maybe explain this better than I??
