thats what bikeman says, they claim 4 hp from a cylinder spacer and a longer piston, not sure if thats right but i asked them about it and they said while primary compression is a good thing, it can also be over done, and that there was not enough air in the crank case to begin with so when they lowered the primary compression ratio they gained power from more air over all...high crankcase compression is usually a gimmick unless it is very low
What are we talking about here , what are you referring to as primary compression ?
I think a key fact of the discussions that gets left out a lot is pure metallic weight of the engine. I know it has been touched here and there on different threads, but it is fact the Polaris engine is the lightest of the bunch. Compared to the Suzuki I have heard it is around 20 pounds. That is a lot of engine weight that can be turned into strength. I'm no engine builder but to say that an engine built out of very similar materials one weighing say 10% less than the other, it should not be a surprise that it produces less power and does not have the longevity.
And whose fault is it they have made it so light and flimsy? Why anyone would be so consumed with saving weight that they would give up reliability is beyond me.
I do think the 800 is slightly under powered compared to the competition.This thread is not a thread about what is wrong with the 800 CFI engine.
It is a thread about "myths" that surround this enigne and whay they may or may not be "myths"
Can we try and stay on topic?
Or maybe I should loose some weight and quit drinking beer while eating pizza when I am watching snowmobile DVD's while my wife is mowing the lawn!
Maybe that would make up for it!
Frickin Funny! I love it!go for the extra power . we all know that other stuff aint gonna happen
(2) There is a "Cold Shot" that causes engine failure: This is a good one and a huge gimmick.. Arctic Cat has had the SAME type as Polaris of coolant system for ever (no by pass loop) and has no issues .. the difference between Cat and Polaris is Polaris has a digital gauge so you can see the actual temps.. Cat has the same temps but no gauge.. Install a gauge on the Cat and ,SUDDENLY, it will have a Cold Shot problem as well... Only Ski Doo utilizes a by-pass loop and they only started doing this in 2000. For more details on why this is simply not an issue please check out this article:WHAT CAUSES and ENGINE to COLD SEIZE?)
FYI.
Arctic Cat has a reverse flow cooling system. This means that when the cold coolant returning to the engine from the tunnel hits the Thermostat it closes. The Polaris on the other hand flows thru the Thermostat to the Tunnel coolers then directly to the water pump on the front of the motor. So the cold coolant that has returned from the tunnel has to flow completely thru the motor before it hits the thermostat. This IS the Cold Shot.
Not picking a fight just educating.
