O
ottawaair
How many miles before failure? How many miles are on your aftermarket pistons?
1,700 on stock pistons. i kept an eye on them with a bore scope camera, thru the Y pipe.
I started seeing the piston crown lifting so talked to the dealer. (still under warranty)
They replaced them with polaris pistons, and at that time found the cracked skirt, so replaced the mono-block as well.
When i got it back, i rode it for 300 miles, it vibrated worse than before, and only had 112 psi compression. Had 118 psi before rebuild.
I ordered wossners, and replaced them myself ( **** the warranty).
I now have 700 miles on the wossy's
All around better running sled.
I measured and weighed all the parts when i replaced them.
I recorded all measurements and can go them if needed.
The wossners were by far a better quality piston.
Thinking of a full kit with head this season.
