Parts on Polaris site still shows parts still under development. Hopefully it will come with either an improved P22 or a P85. Fingers crossed, 6 hail mary's, shoot the cat and pray.Are the 2 clutches interchangeable between matryx boost and NA?
Yes they are. Any 850 primary clutch will fit.Are the 2 clutches interchangeable between matryx boost and NA?
Where did you find the notation?Parts on Polaris site still shows parts still under development.
Thanks, yes the 2023 parts only contain the 550’s sleds
But would you not prefer the P22 to work, since it is lighter, a better bushing desigh for the ramp weights and self adjusting? I know it is the devil you don't know as apposed to the devil you know but I bet it will be better for 23 and have more tuning options coming.Reliability is more important than presumed performance. My TRS set up has worked flawlessly on my 20 RMK and it clearly has improved belt life and performance over stock. Although Our 3 Boost sleds have had no issues with P22 and work well, I will likely use the P85 on my 9R unless directed to do otherwise by Tony…
I sure would. Like most things Polaris, hopefully year 2 fixes all the issues identified last year. If the weaknesses were fixed, my only concern would be the belt to sheave clearances, and sheave design as Tony has alluded to. One would think neither is a bridge too far.But would you not prefer the P22 to work, since it is lighter, a better bushing desigh for the ramp weights and self adjusting? I know it is the devil you don't know as apposed to the devil you know but I bet it will be better for 23 and have more tuning options coming.
