Also, the Jaws pipes fit really well after getting them installed with the motor finally bolted in for the last time the only thing needed (besides a taller hood) was to make some clearance for the MAG pipe in how it wraps around by the center cylinder APV cap, making a new hole out the belly pan for the same MAG cylinder silencer, (the PTO and Center silencers exit out the stock hole) The biggest thing I had to do was tig weld up some 1'' extensions on the silencer outlets to exit farther out of the belly pan (thanks SLP!) The outlets on the JAWS pipes are a massive 42mm ID! JAWS assured me that these are their "trail" pipes for such a setup... After seeing the fitment first hand they are true artists for pipe building... Ill take their word for it at 81-8300RPM which is where they told me these pipes will sing on this engine!
