Did you change your fuel filter?
Check fuel pump and even swap it out.. Maybe its a bad pump or your pick-up filter is plugged..
Not yet that is this weeks project.
Well with my powderlites Nytro I havent had any problems at all here at 1500 feet. I just came back from a ride in Fernie on the weekend. The first day there was no issues other then a part throttle burble but on the second day ( this time I used an ethonal fuel and race gas) at 13 pounds boost the sled would not start when shut off. Gauge was showing no fuel pressure. When left to cool it would show fuel pressure then start. The next day after pulling the screens out of the side vent holes I had no problems . It is a definite heat issue.
After this weekend we have had a few guys run the hose from tank around the side of tank into fuel pump and guys said sled run good all weekend.
If fuel hoses are installed against cooling hoses it will boil gas and pump will not pump because hoses are heated by cooling hoses.
The problem I believe is having the regulator and line sitting in front of the rad.
I agree 100%, this is why I was asking where their fuel regulator were, this could be the main cause to you guys having the fuel so hot and the seeing 0 fuel pressure/fuel vaporizing in the regulator at times. When riding around the flat lands there is alot more air moving past the regulator than in the mountains.
I saw Jrusher did not have his regulator infront of the rad and he has had no problems with the fuel boiling/regulator not working.
anybody have any info on something to wrap the hoses?
