The filter is between the tank and pump. Don't use this filter after the pump as I don't think it is a high pressure filter.
I plumbed everything according to Daves instructions the only thing I did different was mount the fuel reg over and above battery on the frame..
Doesnt the kit call for you to mount the fuel regulator right above/infront of the radiator, This does not seem like a good place to mount it. Alot of heat being put into the fuel system. This would help.
I have 4000 miles on my MCX rearmount and have not had this problem at all. Run both av gas and premium. This is a powderlites issue not a rear mount issue.
This is not a powderlites issue!!!!!!!!!!!!!!!!! this a fuel and a elevation issue my issue was inadaquit venting to my rb3.
Nothing in front of my rad.
Went riding on Sat. with alot of race fuel in the tank, about 5 gallons of 110 and 2 gallons of 91 no ethanol.
Rode all day long and NO ISSUES WHATSOEVER, even had some slow going where the sled got good and hot.
We were at about 8000 ft. elevation, and it was a beautiful and warm day.
Gonna try a bunch of vents and reroute the fuel line and some heat shield, and then slowly cut the race fuel mix down.
I think the issue is clear, guys runnin a bunch of race fuel, or at lower elevation aren't going to see this problem, I don't think it's the kit..
Of course environmental conditions will effect it also......
Who gives a chit if it's the kit, that's not what we're trying to figure out!
That's what is buggin the chit out of me, some guys aren't havin any problems. strange unexplained phenomina
what's buggin me is that i had no issues last season and have had issues this season
You have the MCX still right??
Is it a result of a poorly designed kit, bad instructions, cheep parts, not enough R&D before production??? (not a good job of copying) LMAO Other kits arn't having this prob......
yup.
yesterday was a lot worse than usual & this time i had the entire headlight area vented. It was a very warm day. I can fix the problem by cruising at 1/4 throttle to get air flowing back there but it's annoying. I thought my RAD fan was busted but it was running yesterday.
I am going to look into wrapping the hoses and re-routing them.
