Change the gearing? Is there a lower gearing option with the Q2?A great question too. How could we mitigate what you are describing with the new clutch? (problem currently is the clutch is starting shift out at a higher gear...)
I don't think there is, though I'm sure the aftermarket will come out with something. Problem here is top end of the turbos are obviously high. My guess is (TRS knows best) the way the sheeve is grabbing the belt is causing part of the problem (some slip maybe?). Load is everything for a turbo setup.Change the gearing? Is there a lower gearing option with the Q2?
While waiting for TRS to add inciteful input on the clutching side of the equation...Load is everything for a turbo setup.
Most of what you are going to hear is "compressor surge". As far as I know there is no blowoff valve on the polaris boost buggy. Hence, when the throttle body closes shut, there is a pressure differential. As we all know, pressure will always try and equalize (go from high to low), so if the pressure on the backside of the turbo is less than on the front of the turbo, the air will literally reverse direction in the charge tube and blow past the turbo causing significant air turbulence and the compressor wheel to slow. This is the audible sound you are likely hearing.While waiting for TRS to add inciteful input on the clutching side of the equation...
Since I know very little about turbo setups, I have a question: Is the fluttering sound from the exhaust the pulse input into the muffler from the two sources? The first source would be the exhaust gases coming from the turbo, the second being the gases being routed through the waste gate purging pressure? If this flutter comes from the waste gate valve opening and closing very quickly to maintain a certain pressure that the ECM requires, is there a chance that the mix of components are not exactly size matched for the engine needs? I'm curious if the turbo is slightly too large creating too much pressure requiring it to burp that off and being bigger may add to bottom end bog. Now back to the clutching side, I think one has a direct relationship to the other here. Fire away!
Good feedback. Keep it coming. Few buddies I trust sent me some video, its got lag but their latest (out of break in) the sled seemed pretty damn responsive to me. Requires an aggressive rider but they had nothing but good things to say.From a dead dig, yes the boost has a bit of leg. But so does the turbo doo, if you compare them back to back to the same brand of n.a. once your moving the boost has such a smooth power delivery, almost electric feel. Easiest turbo to ride in the trees.
I took a crappy screen shot of an exhaust can cut-away off youtube to try to illustrate this a little better.The on throttle noise is the sound I’m referring to.
Making sense now, I just remembered they are dumping pressure right out the side of the pipe, and I believe that remains completely separate to the outlet?
Pretty much exactly what you said in the first post, just taking some time to wrap my head around how it works and sounds differently from current aftermarket turbos.
I ended up buying a N/A 165 (for the wife) as the boost isn't here and my axys blew up.So today we had a brand new 165 Matryx Slash Pro NA in the group. I take back what I said about a little lag. The turbo has a huge amount of lag. I have 8 hours on my sled now and the NA was on its first ride. I also might agree with what was said above about the 22 having the snap of a 900. The NA flies out of the snow. I might be trying to find someone to trade this turbo for a 2nd NA. It rips going up hills but it sucks in the trees and it really does take twice the effort to ride. So far nobody who has ridden my turbo likes it better than their NA sled haha
I'll answer this for fun...So even though chadly is an expert rider you don't think he is being aggressive enough?
ExactlyOf course you were[emoji13]. I ride with Chad and Chad needs all the crap one can send. He dishes, so he gets[emoji23][emoji23][emoji23]
