I realize this is a sled forum but your facts in this statement are not correct relative to your personal nitrous application. If you are running 100' there is not a nitrous solenoid with a large enogh orifice to flow 14lbs in that short of time, even with two systems. The MSD 7al will not pull that amount of timing as it is limited to 20 degrees of retard total and would create extreme cross fire with rotor phase issues. If you were able to get the motor to run with that much timing out of it you were sending all your power out the exhaust as max power can only be achieved with full combustion occuring between 5 and 15 degrees after top dead center making it necessary to light the spark even on a big nitrous tune up some time before top dead center. Bottle pressure is key, (as you stated), to have safe and consistent power but anything over 1069 psi will cause nitrous to go sonic and it will have the consistency of foam for lack of a better description, coming out of the bottle and will actually reduce performance as it transitions from liquid to gas. Tuning a 2stroke like you do a 4 stroke can not be acheived by reading the bend on the ground strap of a plug as the 2stroke oil will not show the heat mark on the ground strap. I'm also curious how you managed to get a Big Block chevy to turn 11,000 RPM. If you are running 42 degrees total advance this indicates to me that you are using a conventional 24 degree cylinder head, even with the use of titanium valves and light weight valve train, a 24 degree head will not flow enough air to spin to 11,000 RPM. Current pro-stock 500 Cubic inch motors do not shift this high.
I'm not trying to bust your chops, I just want to make sure that people are getting proper information based on the question asked.
