I officially cant see any more posts in the other one so lets start a new one!![]()
I guess I could add..
My negative experience with RKTEK's kit:
Piston pin clips suk to install
Very hard to heat soak it cause it wont get hot
Arms fall off after repeated wot pulls
Not having to buy a cool PC-V with autotune function "I wanted it"
SLP exhaust wont improve performance "I wanted that too"
Damn you Kelsey!
lol! SLP exhaust does improve performance dramatically tho when "stacked" with the drop in kit... have multiple sleds with just the drop in kit, just the pipe set and now a few like mine with both and it is a pretty big difference
you will have to run race gas at that elevation unless you are running his low compression head even then you may still need some. we ride 5-9k feet and leaving the truck its pretty easy to hit the det sensor until you get up to the 5500-6k+ range.
difference is def. worth the extra coin tho!
What year is yer sled? Kelsey told me that costumers were having det issues at low throttle settings at high altuide, he said it's actually lean not det, but still setting of the det alarm, that's why now especially with the 13s he's recommending usin a fuel controller. He said the 13 have a different map than previous and its leaner. Kelsey has only 1 pro this year and it's big bored so he's relying on costumers to give him feed back with the drop in kit.
my sled is a 13, have 10-15 kits on the snow this year in everything from 2011's with just the drop in kit, to 2012's with just the drop in, 11's and 12's with drop in and pipe set up, unfortunately all of my 13's are running pipe and drop in set up mainly because the combo works so well together, so i have no input on running just the drop in kit on the 13, i'll let somebody body else do the R&D on that. I'm running the 13.5 heads on all of my kits
What fuel controller are you using?
