Looking like the cam arms in the Polaris new P-22 clutches, are way similar to the ones coming from the Cat adapt clutch
The powerbloc for the cat 800 isnt the best set up , we had to put special spring , and a different cap to try and retain the higher engagement point....just saying....powerbloc or 22+ clutch to put on a 2021 cat I don't trust the stock one....
Okay thanks, didnt know that, looks the same on outsideSecondary is actually new with replaceable bushings. Win win!
When are you going to get Pin's and weights completed Kevin?Hubs performance has the new adapt clutches instock.
i was going to order pins from country cat but it added up to $200 for three pins three washers three nuts and six little washers. i think the pricing on the site has to be messed up charging individually instead of for the group of nuts, bolts, washers, etc.
Waiting On weight Washers . Everthing else is in stock. Should be shipping out first of December.When are you going to get Pin's and weights completed Kevin?
I have 3 22 clutches available . I had to have washers and clutch bolt spacers made. I also got enough pins in for about 6 clutches with weights.Waiting On weight Washers . Everthing else is in stock. Should be shipping out first of December.
stock sled or turbo?The powerbloc for the cat 800 isnt the best set up , we had to put special spring , and a different cap to try and retain the higher engagement point....just saying....
Stock and im talkin from a manufacturer point of view..i was there ....Sold plenty with bad review , had to develop something different...stock sled or turbo?
