2011/12 pro
Can i see some pics of your kit installed on a 2012 pro
thanks
thanks
thanks
Went riding at Cooke last weekend and tried out the TKILLC belt drive on my 13 PRO with a new 2:25 gear change at 9 -10,000' and it works great. The TK belt drive is very quiet, there is no whine like the stock QD. The best part is being able to gear the sled down. I was riding at 4-6,000' last year and the sled worked fine but I was only using the first half of the primary clutch. This year At 8-10k altitude with the stock gearing and stock QD the sled was really sluggish and lost the snappy bottom end/mid range it had at the lower elevation. Now with the new system and lower gear the sled has so much more low & mid range grunt and really pulls hard...harder than ever. I marked my primary with a felt pen and all but the last 1/4 to 3/8" or so of the clutch is being used now with the new gearing and stock clutching (62's). Very impressed and will recommend TKILLC belt drive to anyone with a pro. Gear that sled down and it really wakes it up!
My new pro belt drive fix!! Sweet setup by tom at Tkiinc in billings Montana! Well worth the money! You needing a fix for yours give him a call at 406-850-8091. He will hook ya up
I just got mine installed this evening, but I am having some trouble getting the belt to tension up correctly.
What ratio did you go with? Looking at your picture the tensioner is in about the middle of the range, on mine I have it 'all the way tight' and I'm still pretty lose on the belt.
With that said, I went with the lowest gearing available (need it for my clutch setup), and I'm wondering if the belt I got was better sutied to the higher gear ratios (bigger top cog) ... It seems to me like if the belt I got was abotu 1/2" to 3/4" less in diameter it would tension up just fine.
Anybody have this issue?
With all that said however, the rest of the kit went on without a hitch, fit was perfect and no hassle at all installing it. Its a nice looking unit, I can't wait to try it out![]()
I have now mounted 2.52 on two pro rmk -13, on both sled the belt tensioner is bottom out with a belt tension about 15mm.. i am bit worried about that.. and on both sled the belt tensioner is having contact with the brake rotor.. anyone else with these problems?
I found my problem:
As you can see in the first pic, the bolt going through towards the rotor was in backwards from what the pictures of previous installs have shown. I pulled the allen bolt and reversed it, now it clears the rotor.
Also, make sure you put the two thickest washers on the upper bolt ... the 5/16th washers are the thickest of them.
The clearance to the rotor is pretty shallow, but I don't think it will hit. I have mine tensioned up perhaps a bit too tight right now, maybe 5mm .... I think I'll slack it off a bit before I ride it. I fired it up and ran it just a bit and everthing seems to rotate smoothly.
The kit seems to fit just fine after getting the washers and bolts in right![]()
