Motor Mounts causing low RPM in Axys Chassis
I realize checking alignment is probably something that should be done on any sled but why would it change without loosening the front mag side mount when swapping mounts out? Variations/inconsistencies in new mounts? I swapped mine and was still within spec.
x2 not to mention the amount these are out when the motor mounts are actually clapped out, I don't think the manufacturing tolerances on the new inserts are going to be very far off of what the old ones were, and as long as it was close from the factory, I don't see a reason to worry about it if you change them one by one as you are FAR BETTER off than when you started. And this is coming from a machinist by trade who can talk numbers until your ears bleed. Snowmobiles are not precise machines. Get those new inserts in there and run er :rockon:
The inserts are not precision pieces of rubber, BUT most people need to ask themselves, "when was the last time I checked my clutch alignment?". The fixed motor mounts that the rubber isolators ride in can shift from normal riding impacts.
When someone is in the process of swapping out motor mount isolator rubbers and the torque arm rubber, they should just take the 5 minutes to check alignment. Your belt will thank you for the attention to detail...
Off Topic, but CNC Machine Operators are not Machinists
Off Topic, but at only 22 (years of age) you hardly have enough experience to beat your chest and call yourself a machinist. Furthermore, if all you run is CNC stuff then you are a machine operator not a machinist, as your only real function is to check coolant, keep the auto feed hopper full, empty the chip conveyor when necessary, push the green button at the start of your shift and the red button at the end.
Most CNC Machine Operators can not comprehend nor run a manual machine to save their azz, much less make an accurate part.
If youd like to come do my job running 4 and 5 axis lathes and run shafts for GE oil and gas be my guest. Holding more than a dozen turns within .0005, cutting a taper where the .010 standoff tolerance to the taper gauge trigs out to a .0002 tolerance in diameter, and having an entire 100" shaft run within .00005-.0002 runout. Its been a long time since ive had a job order with a quantity larger than one nonetheless been 3.5 years since i sent a part to a dumpster. So if you wanna keep on with the age discrimination, go ahead! Thats not going to change the fact a rubber mounted motor that moves A LOT in a chassis under load is going to move if at all when replacing sacked out motor mounts one by one. I still believe its a good idea to check clutch alignment after install, but i don't think its fair to word it so guys who dont have access to an alignment tool start losing sleep over it...
You need to check engine alignment period!
On the topic of alignment, what tool are you guys using on the Axys, and are you following the specs outlined in the Axys service manual?
I bought the Polaris one. Not cheap, but neither are $200 belts.
I'm not a mechanic so feel free to correct me on this.... Here are some photos for help with replacing the torque limiter part.
The photo with the arrows shows the limiter, and the arm. It sits behind the secondary clutch. Take out the two bolts holding the arm in place (arrows in the photo point to the bolt locations) some heat helped get the bolts loose. Remove the torque arm. Then remove the torque limiter in the other photo (#13 circled) two bolts connect #13 to the Motor. Heat helps with those too. #13 is the part that gets replaced. It has a rubber part to it which is what sacks out over time. The part # is 3022281 Cost like $25.
Remove the torque arm. Then remove the torque limiter in the other photo (#13 circled) two bolts connect #13 to the Motor. Heat helps with those too. #13 is the part that gets replaced. It has a rubber part to it which is what sacks out over time. The part # is 3022712 Cost like $25.
Correct me if I am wrong but........
LIMITER, TORQUE, ENGINE ( item 13)
Polaris
item: 3022281 $26.23
3022712- Is the ; MOUNT, ENGINE, PTO, FRONT
You are correct sagecrusher, the part number posted appears to be incorrect. The one you posted is the correct part number.
Ian
I have a 2016 with just over 1000 miles. I thought I would change these out as some extreme wear shown in this thread. I found mine to be in excellent condition and pretty sure I just wasted $70 and a few hours (First time and turbo made it tough to get mag side done). Here is a picture of a new one next to a used one. Good luck guessing which is which. Plus it is a pain to remove drive clutch.
attachment.php
attachment.php
The one on the left is new. The right one has visible distortion on the rubber fingers, especially visible from 5 to 11 O'clock (which would be the bottom and rear when they were installed [2-8 O'clock]) It may not look like much but it will have had a detrimental effect on performance. Ideally the actual motor mounts should be a harder durometer, these snubbers are a bandaid carried over from the PRO Ride chassis.
Has anyone tried to get this covered under warranty? Or is it considered a “wear” item?
I’m sure it’s easy enough to replace them myself but sometimes I feel like I need to bring issues like these to the attention of the manufacturer and the only way to do that is by hitting them in the wallet.
It’d be worth the extra hassle (and paying the $50 deductible) to haul it to the dealer in hopes of Polaris coming out with a better rubber mount for future customers.
While I do agree that these should probably be replaced under warranty since we are buying $13,000 sleds, these are so easy to change that it isn't worth the effort to load up and haul sled to dealer. The hardest part is getting the clutch off and lifting the stock can out of the way. I replaced the isolators and torque limiter on my 2017 and I am pretty sure I could now do it in under 30 minutes. Very easy. Have a good winter everyone.
Close up on the MAG
For anyone on the fence on changing the motor mounts- do yourself a favor and pull the rear Mag mount- it appears that this is the one most subjected to deterioration, it will open your eyes to change them all - For the cost and ease of doing this, it's a no brainer....
Of the ones I have pulled off sleds, this is the worse by far.
Sled showed ZERO signs of low RPM-and had been running spot on all last year-
This is on a 2016 Axys with 1200 miles...:face-icon-small-dis
Assuming the PRO Ride Chassis Inserts are the same functional dimensions? And assuming that what I read is correct about the PRO Ride inserts being a slightly harder durometer? I would think that a substitution to the PRO Ride inserts would be beneficial to keeping the engine lined up correctly longer? At least on that side / corner.
