So 4 pro mag mounts and call it a day then ?
For those readers that got lost in the 5 pages of info. These are the proride mounts that work fine in the axys sleds.
LIMITER, TORQUE, ENGINE Qty 1
Polaris
item: 3022281
MOUNT, ENGINE INSERT RAD Qty 4
Polaris
item: 3022409
Do it right and do it once- the 18's won't last ya like the 15 pro does...The PRO-RIDE mounts are 25 bucks a pop now, best price I can find. The 16/17's PN's were replaced with the 18' PN, and are ~19 each. 120 bucks on these cheap POS motor mounts shipped is a little retarded... Bad enough to pay close to 90...
New PN's for the 16/17, both 18.59 each.
MOUNT-ENGINE INSERT RAD PTO: 3023290
MOUNT-ENGINE INSERT RAD MAG: 3023291
Think I'll pocket 30 bucks and use the upgrade 18' PTO on all four corners and call it a day. They won't last but a season anyway.
P.S. Torque Arm piece has jumped to just under 40, up 13 bucks from when I looked at in the spring. Polaris must be loving the 500% mark on their consumables.
Was this on an Axys? I thought that was only possible on the 11-15 Pro?After reading this whole thread I think i only saw one mention of the front mag side adjustment for alignment. I was able to loosen the 2 40 tx bolts from under the sled and wiggle the motor some with a strap to get .038 better alignment. Before I was @ .063 now down to .025. I had no idea this was possible as I did not have a shop manual until the other day.
yesWas this on an Axys? I thought that was only possible on the 11-15 Pro?
Sent from my SM-N976U using Tapatalk
