i have a 2002 6 speed, juice w/ attitude, cold air intake, 4" exhaust, banks quick turbo and rv275 injectors and i spike 36psi then the waste gate opens and drops it to 31psi (hopefully gonna adjust my waste gate to hold 36psi this week)
got a j-hook on now. only spiking to 26lbs. 50 bucks for 5 pounds of boost...kinda disapointed....im thinking about wireing the spring so its compressed.....
You may not have enough fuel to substain more boost with than that, especailly not pulling against a load.
Sounds like a boost leak somewhere if your convinced it should be making more boost.
Does the truck smoke? Get up and go well? (as well as a non built auto can go)
Does it have a bigger, more open intake? Like volant or aFE
I'm not sure what the exact numbers are, but keep in mind that if you keep pushing that boost, you may need to think about head studs to save the head gasket. I've got a couple buddies that are into diesel hot-rodding and they have had to go to studs.
http://www.dieseloutfitters.com/DzlStore/
PE
