i have an 01 dodge 24v i have a an intake and edge juice with attitude. im only runnin 19lbs tops i know guys runnin up to 38lbs. how can i get more boost out of my stock turbo?
Check your fuel pressure. With your set up you shoud make 27 to 30 psi. Stock is 18 to 20. Takes fuel to make power and sounds like you are lacking both for what you have. Truck seem to start and run OK? No hidden p0216 in the memory. Air intake OK? What lift pump stock or other? Hope fully not the dodge "in tank fix ".
well you could pinch of the wastegate line so the wastegate stays closed.....but it wont make any more power.
what are your egt's? below 1400* pre turbo?
do you have the pump wire tapped on the vp?
since the edge ALREADY DOES BOOST FOOLING you dont need any type of boost fooler.
The 01 24v's went with the HY9 turbo and a hardlined wastegate actuator, BD diesel makes the "J HOOK" its pretty cheap AND IT WORKS for this turbo!!! You will see 30+ lbs of boost, more power, and cooler EGT's! Once you start to get past 36lbs efficiency falls off, 30-32lbs would be ideal for your fueling.
As far as a lift pump goes, do you have the intank update on the truck? If so its WAY better than the engine mounted junk pump, if you have that get rid of it cause it will go out! Check your fuel supply pressure to the injection pump. With the VP injection pump 15lbs MAX is all you want anything past that can start to blow out internal seals.
perfect! thanks for the help! ill have to look into a j hook! it would be really nice if it lowers egt's. she gets hot as it is btu i just ordered a 5" exh. so hopefully that helps. i have the fass hpfp pump. its mounted on the frame rail but its not the model with the filters and junk.
