The ONLY way you could make 200hp (twin) on 91 octane is with Split Second's 1300 twin, period.
Ive seen almost every variation of 800BB made, even the R's and NONE (Ive seen) of the commercially available ones are above 160. Not EVEN CLOSE to 170. Sorry folks....Most don't crack 155. Stock on this dyno is 138ish for the HO.
After all the hype, most BB 1000-1200 twins come in at 170-185.
Anybody wanting 200hp needs to realize the need to run decent fuel
I have been wanting to say exactly that, If you think you have 200 plus on pump. you are dreaming. I have a 995 (PSI built bt Split Second) that feels like 200 plus & trust me I have Ralphs Dyno sheet that tells me otherwise & if I am not mistaken, don't you have that Dyno now Neil? ... The other problem that you have to deal with is twin pipes. Hard to make serious power without them, & hard to get them to fit properly in the Rev. Ralphs 1300 would give you what you need but $$$$...Anyway PSI & other BB engine builders like to promote 200 plus, I guess that is what sells. I think PSI says my motor is 212 or something like that. I have spent a lot of $$ between Linderman & Ralph & it is still under 200....Just my 02
So, with the above being said - does this info point me towards a triple with the the nightmare of not two pipes, but three, in the rev chassis??? The fuel is a given - if you need to run race fuel, then that's what you have to do!!!
Thanks for your input!!!
If you want to make the big power you are going to have to compromise somewhere. You're not going to make 200 HP on any twin with a single pipe and stock settings unless there is a blower mounted on the end of that pipe, and even then it won't be stock reliable, you will have to compromise. The 809 does fit into that chassis and worked over right could put out 200 HP, Ken at Specialty built one for sure, and there have been others. Neil could build you some pipes. Or like Canucklehead said, bolt a 4 stroke yammy in there with a turbo on it.
In a nice light chassis though, a 180 HP motor will outperform a heavier 200 HP sled, and will likely last longer. Something to think about if this is what you're contemplating.
I know of a local guy on SW with a vector 3 cyl with a turbo in his Rev, That thing will make a Mark. It is a ton of work but he has some serious power.
We saw one, maybe the same one in Keystone one day... it is the real deal.
Not the carbon fiber one, that guy is a reve local I believe.
Not the carbon fiber one, that guy is a reve local I believe. The one we saw was from Edmonton area.
