It won't interfere with the throttle cable. I was actually messing around with my bar setup last night and found something interesting.
The SnoPro throttle block from the 600 Racer accepts the M7 throttle cable perfectly. I was expecting to have to buy a different throttle cable but this one fits perfect. However, with the adjustable post, I am either going to need to upgrade to the newer style cable, which I am not sure is the same end, OR try to find a throttle cable extension kit, which I think AC makes? and use that.
I have one that's made by powermadd, it is a long extension, it accepts the m7 throttle cable and the firecat throttle cable(same ends, different length) Honestly running an extension kind of scares me because whats stopped moisture from getting in there and then freezing? Sure you put white lithium grease in it but there's always a chance to have a run away sled. I would opt to get a new throttle cable to be honest. How long is your cable? I have an extra firecat cable laying around, mine may be longer. They have different part numbers. 0687-155 & 0687-168
I have the adjustable post and I honestly never even move it. It stays down all the time. Haha
Bam. Got my a arms in. These things not only look great, but overall just a very nice product. Came with all the bushings, tie rods, and arms. Now I am debating on whether I should bring these to the powder coated and have them done up black like my original plan. Or do I keep them red? I have a set of C&A SKI's on their way and they are white. I could do the spindles in a black and keep the arms red? Or go all black?
I went with the newer style adjustable steering post. Which the stock kit, does not fit the older M7 without drilling a new hole in the bulk head. Since I have a brand new bulk head, and already re-enforced the steering plate, I opted to to go a different route.
I bought a used post off the forums swapmeet. You can see in the picture where the socket is that I had welded. The top half is basically casted and machined. I just cut out the newer style "bottom half" from this socket, and replaced it with the bottom half of the stock M7 post. I don't see why this wont be just as strong as before. I installed it this afternoon and everything seems to line up correctly.
My question is about my brake line cable with the newer PC bars. I would like to actually put another bend cable end, to get it closer to the center o the bars, but I have never attempted to try and don't even know if it's possible. What do you think? Should I just leave it?
4"/100mm from skirt for egt's .
I would highly recommend an aftermarket Y pipe.
