I've managed to get some work done the last few days..My mag side cylinder was originally damaged, sent it out to Racin Station and got a new one. I choose to go with SPI pistons. I know of a lot of guys who have ran them in their sleds with no problems so I figured I would try them. Top end install was pretty straight forward if you have rebuilt a 2 stroke. Their were a few things I made sure to be extra careful on. One being the piston to cylinder wall clearance and the ring gap. Both cylinders were spot on with each other with each piston riding in the appropriate cylinder. My ring gap I managed to set at .017" on both sides. I know a lot of guys really stress about getting this right. I think I read somewhere with the stock OEM pistons you want a min. of 012" and even more with aftermarket.
I made sure to clean my power valves good. I know they aren't shiny, but I removed all of the carbon build up, installed new seals, and cable O-Rings which were surprisingly worn and begin to degrade so I am glad I replaced them.
When I installed my BDX oil delete, I decided to go with the grease line instead. I already had my case together and didn't want to split it, and I feel this is an adequate way to lube the water pump shaft. Once I install the throttle bodies I am going to fasten a mount somewhere to the rail, similar to what BCL did on the ProClimb BDX install.
It does feel good having the motor sitting in the chassis finally. I found a bad mount which needs to be replaced on the mag side. I will hopefully get the throttle bodies and wiring harness installed tomorrow.
I have had like 3 different handlebar setups so far. I finally got an adjustable post off of here and am modifying it to fit in the M7. I am going to stick with the ProClimb bars and SnoPro throttle block as a bar setup.
Im still somewhat hesitant about running another exhaust because I have heard of so many "bog" issues or tuning issues people have had with them. I may just stick with the stock pipe and suitcase to start with a baseline.
