Originally Posted by
indydan
You started it. I hate this sh!t.
You posted your drop in kit & your big bore. then you followed that by saying there was no problems with anything other then the piston.
Never said that EVER... Again.. no need to post things that are simply untrue.
I said I am addressing an issue. (and I am). Not fixing ALL the issues associated with the engine.. Check it out.
Just offering a viable and affordable solution to one of the engine's shortcomings...
It is not stated anywhere where there are not other issues associated with that engine.. We both know that the engine is not perfect..
Check it out.. the website is public as are these forums.
You started this, I have been trying to stay away from thrashing you about all this for the last 4 weeks. But you keep coming at me.
I have NEVER come at you,, You entered My FYI threads on the Pro with negativity.. I have NEVER stated anything negative about you or your products on this forum.. EVER.. You can not say the same.
I Simply am offering a solution to problem.. nothing more.. and asking a few questions.
Hopefully, last post to clear up a few things.. Please see above..
I entered your FYI thread ( Rare for me ) You have tried to perfect this move. You knew I offered a longer rod, & you said plain and simple right to the point ( The 800 PRO does not have a rod ratio problem )
The motor has a poor rod ratio and because the piston is hot the poor rod ratio over stress the piston. ( I address it my way, You address it your way.)
Your questions are rarely questions, They are set-ups most of the time and when you direct them at me they most often backfire.
The bottom-line is the people want to hear every angle there is on the Polaris 800 Small Block. And you love to blow your horn, So I blew mine back. I did not say anything to slander you or you shop. I said do a search.........It is no secret I hate forged pistons. Chances are I have bored more cylinders and installed more pistons in sleds & outboards then anyone on this forum and many other forums added together. ( Forged pistons fail more then any other piston period. ) And when I say fail I mean fail sooner and lose power faster then any OEM Polaris Piston ever made. Forged pistons expand more then OEM cast, So in order to run them...........You have to do 1 or more of a list of things.
#1 - run more clearance
#2 - run more top to bottom taper
#3 - Drill them with oil holes where ever there is an exhaust bridge
#4 - Cam cut them and reduce them in size more in places where they are prone to stick.
If you measure a Polaris cast pistons in 10 key places and make a matched sized forged piston and run the same clearance the forged will stick the first time you hit the throttle with a cool motor.
This is not a guess, This is hard cold facts. Wiseco told me years ago That the forging process does not permit high silicon content. Low silicon
pistons bend & over expanded. Thats what they do.
I started my business building forged piston big bores. Train wreck is all I can say.
Steel sleeves & OEM clearances with wiscos still spells desaster in many motors. I did 2 outboards within the last 2 years both Dealers were at a cross roads for piston size and wiseco was the easy way out. Both went down the first time out.
Kelsey I don't know what kind of piston your running and I do not care.
Thats your business. The picture I saw of your 858 cylinder looks just like a forged wiseco was in it that was to tight. seen hundreds and hundreds of them. Same look different story.
Bottom-line - You can say what you want to say, I can say what I want to say.
I came on here addressing an issue -
I back it with a warranty. ( My Choice )
You came on here addressing an issue -
You don't back it with a warranty ( Your choice )
As you say its an open forum.
Dan
