3 Year Top to Bottom Warranty
* ( Long Rod Torque Master 3 ) *
Well its finally here & ready for 2012/2013.
After years of studying the 800 Small Block.
The design problems have been addressed. * ( and Back with a Warranty that proves it. ) *
Nick Named - The LR-TM3 PRO Motor for all 2011,12
*( Long Rod Torque Master 5 ) *
*( There will Also be a LR-TM5 2011 Thru 2013 available ) * Being Polaris as not yet address the rod ratio problem. And their extended warranty is covered by an outside insurance company.......Seems they don't even have confidence in their new CFI2 Motors either. Try and find ( Extend FACTORY Warranty ) Polaris covers a new sled for 1 year. Just think how many 2012's their will be out there with zero miles and zero factory warranty.
The Motor is fully assembled, Case, Crank, Pistons, Cylinder, & Head.
You just add your ignition & fuel system.
It has a Top To Bottom 3 Year warranty, and almost everything is under warranty....Pistons include. Unless they are melted from a lean condition, Detonated or impacted by the exhust valve.
Price - $2500.00 Stock Compression ratio.
Polaris dealers Welcome, ( And Dealer Pricing Available )
This Motor requires a Core return Motor. - Case, Crankshaft, Cylinder, Head, Head cover & all bolts required for assembly.
Cylinder Core Requirements - It does NOT matter if the lower cylinder sleeve extensions are broke, But cylinder must not have any other external damage, Cylinder Plating can be trashed it doesn't matter.
Crankshaft Core Requirement - PTO & MAG - end & center pin must be in perfect condition, center wheels & lower rod pins in perfect condition.
Head Core Requirements - Undamaged ( No dings )
Crankcase Core Requirements - Good bearing bores & No cracks or holes.
There is also a 5 Year warranty LR-TM5 that has no core requirements
other then sending in your motor no matter what the condition but it must be complete with all Nuts & Bolts. NO IGNITION, and NO FUEL SYSTEM.
Dan
