Let's see your rigs!!!
5.00 star(s)
Mr. I-drink-a-whisky-by-the-gallon:
That is so interesting that you snuck 34's under that!
You have some amount of lift? It doesn't look like it (compared to ride heights nowadays)
No fender trimming?
That's like stuffing 35's under a stock F250 "High-boy". ('77 and older)
Filled it up nice and no need for aftermarket lift.
Is that a 5th wheel camper frame, or an all custom job? Good idea either way
it is a 2002 5th wheel camper frame. was tipped over and stripped. did a lot of welding but turned out pretty well. 6 sleds easy and possibly 7 have not tried yet.
I did the conversion, started life as a crew longbed 3500. Used half of a front door and half of a rear door to make the middle doors. Added the extended cab and a 5' 8" bed. Took a little over 200 hrs and the interior still needs a little work. Wanted full 6 doors but had to keep it as short as possible since its my daily driver.
Incredible work ljothen!
looks great - you're a better man than i for dd'ing that bad boy!
Tow & Camp Earth Roamer
Allows us to chase the weather and camp on the go, water system works to below zero. We tow a 26' Mirage, pimped out to the max and color coordinated with the Earth Roamer.
The back seat has suicides tho right?
Another Turtle Expeditioner too!
Prolly lost your chance to cross Siberia tho. :face-icon-small-sad
Recently flat bedded my half ton for two sleds. It's an all steel deck, 1.5" 14ga. square tube for framing, 14ga. plate for decking. Ramp storage under the deck, LED lighting, DIY roll-on bedliner, bolt on side & ski glides, ski hold down bar nut welded in place too. Weighs a little over 400lbs, which is about the weight of the stock bed. Receiver hitch sits 1/4" higher than stock, so if it's not lighter, it at least shifts weight forward some. Haven't hauled two sleds quite yet, but this F150 is sprung pretty heavy and I'm not concerned. I'm happy with how it turned out. Took longer than expected, but I'm a slower fabricator than I remember.
20141129_200219.jpg 20141130_004418.jpg 20141202_101025.jpg 20141206_095144.jpg
You forgot to mention the sick mud flaps!:thumb:
Just curious, what does it cost, relatively, to stretch a truck out like that?
$5k, $20k?
I did all the work myself so the cost was fairly low, only costly items were rims, tires, step bars and extra seats. Guessing to have it done would be around 15-20k.
