Next is Skinz Protective gear Heated Break lever. Ive ran this for a while now and find I can't live without it now! It is easy plug and play on the connector and as you can see has a much better angle for using a single finger. It's also adjustable for every size hand. Be careful when you remove the tiny clip under the break reservoir. You will also have to reuse the spring for the break lock shown below. If the powder coating is to thick you can lightly drill it out with a 5/16" bit.
