as trading my sled for yours? completely not feasible. I am in EUWhere do you live. I have a 9r pro 165 coming and might consider trading if it is feasible
my dealer has a track, all I need is to get rails from the US (and miscellaneous parts)I have a 9R 165 coming and I will be swapping everything to go with a 162 3.0 PC. If you want to wait and get everything from it I would be willing to work with you but who knows when the sled will be showing up.
I believe tracks USA makes them toOne option would be to just buy rail extensions. It’ll much cheaper to ship and easier on your end to install. Vohk makes and sells them. They even can powder coat the same color as your stock rails. I would call them for help on your complete set up.
Also, if your staying with the Polaris 2.75 track you use the same driver, 3.5” pitch. If you goto a different track, you may need a different pitch driver. Just depends on the track you want.
Sent you a pm. I have a 9r 155 pro coming and am thinking about swapping to a 165Where do you live. I have a 9r pro 165 coming and might consider trading if it is feasible
Yep, all I could get was a 155 9r khaos as well, but I wanted a 155 pro. Sounds like just a pro limiter strap will pretty much get me there?
If they reflect production in ‘22 and are Velocity shocks, they are the same. Only the limiter strap is different.
Yes.Im not in EU.
and yep, it is a khaos so it has the velocity Hi-Lo shocks.
TRS, are you saying the only thing I need to mess with is the limiter strap?
^^^^^^yesIm not in EU.
