I noticed my engagement was higher when revving it on the stand too but when I took it out for a ride I never noticed it at all. For track tension just set it to factory spec.
The new weights for the lower elevation are super accurate when I weighted all 3. These are the Mountain Mod Indy Specialty weights for 2020, still lots of room for more magnets if you add more power, and of course easy to take out weight to dial in perfect RPM when going up in elevation. When I weighted the 3 weights in the last pic 2 were exactly the same the 3 was 0.1 gram different That is precise! 1st pic below doesn't have all the magnets in and 3rd pic also has 3 magnets holes open when I took the pic.I am so impressed with Dans setup, I also did the balance,machine and trushift cover along with a full sea level clutching kit. Silky smooth and lowest heat Ive ever had in my clutchs
Your engagement will be different slightly on the snow than the stand. You can adjust it with placement of the magnets on the adjustable wights or from changing the primary spring. Springs are cheap and some of us keep a few around to dial in what we like (everyone has a slight different preference) I like a smooth engagement on the snow when Im in the trees for example that lets me be picky with lines without trenching. Same sled if I was still racing hill climb would be a much higher engagement that would absolutely stink boon docking or in the trees. It's funny to me when I have someone switch sleds with me for a few minutes so I can "see how their's rips" they tell me and they have it set up like a snowcross race sled and cant figure out why they are stuck all dayI received my clutches from Dan today. Those were the last piece I was waiting for. Assembled everything together and started the sled up. Adjusting the track tension and making sure the track is centered inside the tunnel. I ride elevation wise 6 - 9 thousand feet spend most of the time in the trees.
First thing I did notice track engagement was at 4200 rpm while on the stand. Is that to high of engagement rpm should I adjust the weight to bring the engagement rpm down?
Second how loose should the track tension be? As loose as the track can be before it ratchets? It does have IceAge rails and anti-stab.
damx can you post the Indy specialty Mountain set up the same way as above?The chart I put up is from indy's wed site.
The new weights for the lower elevation are super accurate when I weighted all 3. These are the Mountain Mod Indy Specialty weights for 2020, still lots of room for more magnets if you add more power, and of course easy to take out weight to dial in perfect RPM when going up in elevation. When I weighted the 3 weights in the last pic 2 were exactly the same the 3 was 0.1 gram different That is precise!View attachment 336534View attachment 336535View attachment 336536
No, there is room in each hole for more magnets, I was just showing that pic as an example. I use a sharpie on the scale so I place them in the exact same spot each time to get the most accurate weight.So those are fully loaded at 71g? They cant be 850 weights if thats all they are for low elevation?
that weight has some material removed, the low elevation(trail)weight does not have that. Mine came set at 3-2-2-2 which is 73.5gr on the scale.
Mine came set the same way, I took the pic above when I had some of the magnets out. I should have specified that it was just a reference pic. I do a lot of riding in Upper MI around 600-1000ft.that weight has some material removed, the low elevation(trail)weight does not have that. Mine came set at 3-2-2-2 which is 73.5gr on the scale.
Mine came with the same springs. They have a number of different helix's, mine has the Mountain 1 RCTS-Full. If your swapping helix's it's a Torx T-27 not a T-25 like some use. They have thread lock and might strip. If they are hard to remove heat them up with a heat gun or a low flame propane torch.Im at about 1800 ft and I think mine came setup at 76 grams. Green/black primary, red/ light blue secondary and the helix is the trail version 62 or 66.
I hit 8350 to 8400. So will add a magnet and go from there it flat out rips ..trail weights ..turbo3 helix..160/240 spring and green primary. You can also drop the finish rate on the primary . But test in powder not on trail. I test in powder with a good load on the track cause thats when you want proper rpmIm at about 1800 ft and I think mine came setup at 76 grams. Green/black primary, red/ light blue secondary and the helix is the trail version 62 or 66.
