Just brought my new pro
Picked up my 2014 800 155 pro this morning. Very nice looking sled. I'm coming off of a Nytro and hope I like the big change
Id be lying if I said I wasn't nervous.
Here's a pic!
[/URL][/IMG]
Congrats. You're gonna love this sled.
Some basic Pro longevity stuff
1) Run the best gas you can find (non-eth if available)
2) Make sure your resistor is set correctly for the gas you are running
3) Turn up your oiler to 40:1 (about 2.5 to 2.75 turns)
4) Check your oil cap for proper venting
5) Follow your break-in protocols
6) Make sure your suspension is set for your RTR weight
7) Warm it up every time (120* or better) before taking off
8) Add some scratchers and run them whenever the snow is thin or hard
9) Route your exhaust solenoid vent tube outside the belly pan
Then ride the piss out of it
We bought ours from Bristows. They had the best pricing I could find. Haven't needed service yet, knock on wood.... Nothing to be nervous about, just ride it and if something happens, deal with it. I quit worrying about it. If the motor goes, it goes and I do an 858. Win win the way I see it!
Thanks for the good info-
I also bought a new 2014 but a 163 and havent been on a polaris in YEARS-
There are always some great tips from the start but have to dig for hours on here for them - Thanks for the highlights- any other venting- close wires ECT we should look out for?
I need to find out the resistor your talking about ans also look into the TPS correction I have been reading about..
S/C
The fuel setting is changed through your guage. Inside the side panel on the left side tells you how to change it, or the owners manual. The resistor was used up to 2012. Congrates on your purchace. :face-icon-small-coo
food for thought. as far as the eth mode, it is my understanding that it adds fuel for ETH setting to compensate for the leaner Ethanol, so it wont ping at low elevation. that said since i ride 5500 ft+ i always have mine on non-eth and run 91ETH. plugs look good and runs cleaner.
I would eliminate the altitude from the equation, because as far as I know this motor has an altitude compensator providing input to the ECU. Run the appropriate setting for the fuel you are running, regardless of elevation. Unless you are willing to bet your motor on the quality of fuel that the pump SAYS it's supposed to be......LOL
AweSome feedback guys. Pretty stoked to ride it.
The dealer told me to just keep it in ETH setting and that I have to change the weights for running low altitude, should I just follow the diagram in the manual?
I have 6 months to decide on warranty so if I like it ill extend it and not worry about some of the things on the list. Does the oil adjuster have paint on it to show if someone tampered with it.
Where are you going to ride it? If it's in MN I would clutch for that altitude and leave it in ethanol mode unless you can get non-ethanol fuel. Here in Colorado I run it on non ethanol even with ethanol fuel. Altitude makes all the difference as the ECU compensates anyway and runs a little richer.
If you bought it from a dealer in your area- part of the purchase is setting it up for where you ride-
Came off of nytros last year to pro 600's and it was night and day difference re handling. Very few stucks compared to the nytro and the pro went places I wouldn't have tried on the nytro. 1000 miles on each sled without issues.
Here's a pic!
[/URL][/IMG]
Yes thanks for posting a basic starter list as I also just purchased a 14 Pro 800 to ride this year after owning cats all my life, this will save a few people on here hours of searching.
Noob question...How do you check the oil caps venting?
FYI: This is driven by the concern that if the vent gets plugged you'll create enough of a vacuum in the oil tank to slow or stop oil flow into the pump, causing a burn down.
The simplest way to check is to try and blow throw the cap. It should have a small (1/64th?) vent hole. Some guys were drilling this out to 3/64ths or 1/16th to ensure better venting.
The possible negative to this is if your sled is upside down for too long you'll end up with an oily mess under the hood.
Okay, I think I would just with the paaso racing vented cap, I just wanted to know how to check if the vent was good when looking at used sleds. Thanks for the tip!
Here's a pic!
[/URL][/IMG]
I put money down on a 163" from Bristow's last Thursday, small world ! Now to find time to go pick it up. Been on Ski Doo last three sleds, but back to Polaris for now.
