Jacobson roll over valve
On the new style MCX Nytro's there is a ton of room as they have the tank in the intercooler and it's just like stock to install. On the other's it is a bit tight but it fit's. We haven't had one yet that wouldn't fit between the oil and overflow tank. You can cut a barb off each end of the aluminum tee that gives another 1/2" and still lots to clamp (use a zip ty)
I like the look of the OFT kit for my Apex. It is well put together and built well. It works as advertised thus far on the work bench. I also like the way the tether looks and works !
However, one thing i did not like is the solenoid valve itself ! The barbs are glued to the solenoid valve and i ended up breaking one off (filter side) while pushing on a hose. Not very impressed LOL. I ended up using some sealant/adhesive and glued it back on. I also did not like the size of the clamps in the kit. Way to wide and goddy looking. I used some thin band hose clamps which worked better and actually held the barb on to the valve while the glue dried.
It is a nice piece all in all other than a couple of minor gripes !
