What did you do in terms of thermostat for your Steel Frame 500? Run two thermos? "Y" the two hoses into one to get it into one thermo? Or?
Anyone make an inline valve that the more you open it for the secondary route, the more it closes the main route? Could essentially make a valve that has your feed and return built in, mount it enroute to left radiator, then you could adjust dial to the amount of heat needed for carb, and all the coolant goes through the rad still. I would assume such a valve exists already.Kind of late now but something to keep in mind for the future, both SB and I tapped the boss on the back of the head which we use to feed the carb heater. I welded a return fitting onto the bottom of each of our left rads. Clean and simple, works great. I hope you prove us wrong but I think you'll be dead in the water with no carb heat.
M5
What year 450 is your build? I just picked up an 02 and am currently dreaming of a similar setup.
I wonder if avid would sell a carb heater without thermostat, so I wouldn't have to do the extra combining of hoses, and then I can just crack it open as much as is needed.
I have the PJ carb, and don't see it listed as an option on their site either.
Hey not bad, think I would rather go that route and get my own piping for it, so I have complete control over it. Just need to find the right hardware.He sold me just the carb collar. works great! put it on my ktm 300 lectron
$100
The pwk fits the pj. It fit mine. I had to sand the carb down just a little to get it to slide on. Just the burrs really. The problem is making it fit in your frame. It's a little bigger than i thought it was gonna be. Hopefully you can make it work with yours. I wish someone would produce a round one like m5 and summitboy made for themselves!
