It isn't perfect, and a few things I wanted to be a bit different on it, but it is done, and no going back now. Have the weekend to put in a good amount of time back into it. Should get the motor mounted if everything still lines up, then the tires and everything I can. One concern is the angle of the radiator modification, it was marked, and somehow ended up with very little turn in it, I'm afraid it will hit the pipe. So might have to redo it somehow.
Will try to fit up rad hoses that I can, figure out what lengths of wire I need to fit the new coil and ignition locations. Also need to order a new hose to return from pump to rear of engine, I just need to find that thread that had the particular auto hose with the right bend you just trimmed a little off one end. Will need to also do some heating of the gas tank and pushing up where the petcock is located.
I have a list of minor parts I still need, like a foot peg spring, and several other things. Will order as much as I can together once I have a better idea where the project stands after this weekend.
Also the seat mount threads are all kinds of jacked up, is it possible to press out the nut and press in new ones? I actually salvaged the nut from the fuel petcock tab that he broke off, drilled a new hole in a piece of plate scrap, and pressed it back in, and had it welded to the frame. But I'm not sure I could safely press out these nut fittings, nor where I would get replacements, open to ideas there.
Other than that probably won't lock tight or fully tighten engine mount bolts until I have the thing fully assembled and done, then go back through it after I know I won't be taking it apart again several times.
Planning on using the timbersled intake for summer and throw a k+n fabric filter on the end of it. Unless it is too small. I know the GYTR fabric filter on my wife's quad is absolutely massive. So I likely won't fire the bike up until I pick up my kit in a few weeks. But I have just about that much work left to do anyways. Then it will be testing the bike out, and breaking in the motor around here before the snow hits, then on with the track!
