Your regulator should have 2 nipples on it. One that has fuel pressure that goes to the guage. The other should come from the AIRBOX not the pipe. This is what the regulator references off of to keep the pressure 3-5 psi above boost levels.
There will be a nipple on the airbox that will go to the regulator, boost guage, wastegate actuator, and the tops of both carbs. It's going to look like Medusa when you're done.
Maybe I'm missing something but the fuel pressure regulator is referenced off of airbox pressure.
Why in the he!! Is everyone saying to put a port in the pipe to get this? The last thing I would want is to port over 900* - 1300* exhaust gasses to the controller running the fuel. Even if you get REALLY GOOD SILICONE hose, its going to melt the crap out of any hose that you put on there. Once you melt that hose you no longer have boost referenced fuel pressure and you WILL go lean. If you have 7 psi fuel pressure (not referenced above boost) and 9 psi boost, the boost pressure can push air into your fuel tank from the carb through the regulator. No fuel and you will go lean faster than you can shut it down.
The hottest your airbox will get is a couple hundred degrees and that is if you heatsoak the crap out of it with a really long pull and no intercooler.
GI Jones
Because in the 22 yrs I have been doing it that way you never run out of fuel volume at any boost level and the temps are nowhere near what you think..
FYI, EVEN KTM is now using MY technique on their mx bikes to operate the ex valve !!! with nothing more than 1/4 inch vacuum line !!!!!
Many thought the heat would be an issue.. Now even the OEM knows its not..
Once you understand the relationship of fuel delivery Before boost build you'll get it..
Its NOT mandatory, many still get along fine using the airbox .
For higher boost longer duration pulls on the hammer you damn well want fuel pressure 10 psi over boost.
When you try it, and see that your engine runns the same, you then can surmize the fact that even at the higher pressure you still have NOT overcome the demand for fuel and its not flooding out ?? tells you you still need more to be safe at the 30 [si plus level.
I used this method in the 1988 selds and it was the END to all fuel handling issues.. you can run your base pressure at 2 psi for clean response on and off the throttle too..pipe pressure should be 3-5 minimum over boost, so fuel pressure will rise in advance to boost and will be that same 5 psi over your base.
In my applications for drag racing and speedruns we see 12 -14 psi fuel pressure over boost and have @ dynotech the smoothest fuel flow numbers EVER for a turbo 2 stroke !!! primative carbs they say !!!!! LOL still doing exactly what we tell them too...
Dooin-it, I think his engines electical system is so far ahead of the one that old capacitor was designed for it would be moot for him to use that antique program..
he has all the current he needs to run it like the doo carbs directly from his 12 v dc charging lead..
i could be wrong though as I am no polaris pro tuner for sure.
Gus
