does anyone know if this can be made to fit, work with the 2018 XF HIGH COUNTRY 141? Ski
The new spindles move the skis forward quite a bit. I put mine on one side at a time last night and the side with the iceage spindle, the ski was quite a bit farther forward.
18 and 19 are both the same height.
14 is ~1" higher...
Is ur 17 mtn cat the same as my 18/19?
i Lifted the bumper to make sure there was no sag.17MC is where your 14 is looks like. about 12.5" how you measured from the track edge to center.
Ask Iceage to build a 141" elevate rail, shouldn't be that hard. Or just swap to a 153" track, the High country uses a 153" tunnel.
reduce![]()
have a 141, and a 153 high country, the 153 tunnel is approx 4-5" longer could we make it work with the 153 rails? sure but, it would be tight, especially if it bottoms out. Ski
Haha yes! That's what I meant to say. Annoying.Adding the holes wasn’t difficult. Just annoying. For the amount spent I would not expect to have to drill missing holes and machine my own bushings
Any update on the upper A-arm?Please email us at iceagesales@gmail.com and we would love to help you with shock setup to get your sled working the way you want.
With the higher lift in the front with less in the rear promotes weight rolled back and onto the center track shock and off the skis. Imbalanced shock configurations or other setup issues can (just like on a stock sled) make the sled rather unpleasant to ride.
I have a 2014 High country 141 and it has a full size 153" tunnel, maybe later years got the 137" tunnel?
It is deeper than the gripper.^does the 19 ski still have that maga deep keel? I know the trailing edge was improved but I still can't stand cat skis.
