If you can't make it run normally aspirated, why on earth do you think you can make it run on boost?!?!?
That doesn't seem quite right in the specs but I don't know that much yet. maybe someone that does know for sure will chime in.
My thoughts exactly...
I agree. You definately have a lot to learn about clutching, piston wah, and the sorts. Spend your money on some different clutch springs to experiment with, maybe a new rear skid and learn the basics. When you have those nailed then you can use that knowledge to tune your turbo in. There's no point pushing 250hp at the primary with a turbo and only being able to get 80 to the ground. You be more disapointed in the machine than you are right now, and broke on top of that
That would be the small framed verison with internal waste gate more likley.
the comp wheel is much smaller than std frame 3076 without the internal gate option..
check the specs of both and you will see they are quite different..
u no wanty small framey...
Gus
