So this is the turbo of running boards?
Good luck.
Good luck.
Good luck.
From the pictures, it looks like you have to cut off your entire stock running board basically and lay this in it's place??? How does it keep it's strength and not twist from weight applied if there is nothing to support the outer edge? Is it just supported on the whole outer edge by up in the very front in the foot-well and the back part there alone? Also, from my experience, any kind of ice-screw is basically a sheetmetal screw and loosens up over time. What are you doing to keep all of these "sheetmetal screws" tight over time? Great concept, but very skeptical of the design?
Aaron
Aaron
looks like someone got drunk and threw some pretzels! way over engineered were not building rockets. and if im gonna buy a bag that costs 180 bucks it better go on my back when im done.... wait a minute did i just say that! heck 400 bucks and a backpack from wally world a bunch of beer a bbq and food hell thats a week of fun for four guys. sorry i know you meant well but wow i can hold a 18 pack and 2.6 gallons of spodie here. and look at my boards there clean except for side of tunnel and back of foot hold . AT LEAST YOU DID'NT SPEND ALOT OF TIME ON THEM!![]()
Yes, you DO cut off your entire running board. The new boards mount in the exact same locations as the stock set up. The mounting points are the same and the outside rail is stronger or equal too oem....agreed?
The part that fills in the rest is now tubular aluminum vs aluminum sheet metal. In my world that means stronger, either way at the VERY least they wouldn't be any worse than your stock boards. Hypothetically.
It depends how the inside tube mounts to the tunnel? I don't see any hardware. IF it is attached to the tunnel from underneath or from inside the tunnel with steel rivets it should theoretically be strong enough. If it is not, than that outside tube is just going to act like a pivot point and cause major problems. Also, you didn't address the "sheetmetal" screws loosening or backing out?
Aaron
Aaron
You have to drill all the studs in on your own? I'd think @ $500 you could have at least done that.
In my opinion, they are!!
