HOT NEW PRODUCT - M-Series Air Frame Running Boards
If I were you I would put some of those screws on the inside rail as well. (unless you did and I just can't see them). Otherwise you will probably slide down the inside rail if you have all your weight on it rather then the middle. You could probably space them out a bit more on the outer rail. IMO... they look a bit like the seating on an air transat plane. LOL! JJ.
I do not know what the warranty is. I would have needed a new tunnel/bulkhead or some other sort of snow eliminating board so warranty wasn't my primary concern. There was mention about a special coating on the screws so I'm not sure if I'd powder coat them or not....
Trax 2 Treadz in Canada www.trax2treadz.com had one last set and they got them out to me faster than lightening!!! Thanx Larry and Jan!! Here are some pictures of the install if you are interested in how they are installed....
WOW you put A LOT of screws in! Looks good.
What kind of warranty do these boards have on them? If for some reason they did decide to crack, break or bend. I weigh 225lb and I'm always jumping from board to board (love boondockin' in the trees and dropping in off 20' cornices)...I really like the look and design of them, but I believe you better have a good warranty if I'm going to be cutting my oem boards off. I should probably look at the skinz website, but could you tell me what material the screws are made of? and can I get them Powder coated a different color? :face-icon-small-coo
Skinz warranty is next to none so I would NEVER be concerned about that. If they are at fault they make it right. Now if it's obvious that you did something to them to cause the issue they'll know. Skinz not only builds products for snowmobilers but truly cares if the customer is happy with their products. The screws are some type of coated steel traction screw, I wouldn't powdercoat them. The coating is to keep them from corroding where they come in contact with the aluminum tubes. If you were asking can you get the boards p/c then the answer is yes, just will take longer to get.
I hope to be installing them on my 2012 Pro before I even ride it.
If anyone is in the market for a set of these we have a few sets available in polished aluminum. $464.95
