NEW PRICE! ASCENDER PLASTIC UPGRADE KIT WITH PROMAX HOOD INTAKE, OIL TANK, PRO-BOARDS
If you have a 2012-2017 Arctic Cat ProClimb 800 or 600, and you want to upgrade it to the 2018 Ascender hood and panels, then this is the best way to upgrade your machine!
This kit comes with all new BLACK front end plastics off of the 2018 Arctic Cat Ascender chassis. Hood panels, side panels, belly-pans, hood vents, cowl, hardware and fasteners.
Next is the PROMAX Cold Air Induction hood. It eliminates the stock headlight and comes with a new molded pod assembly. The pod houses the instrument gauge, ignition switch, accessory plug, and has built in cold air intake on each side of the gauge.
The cold air is drawn in through two areas in the nose of the machine, hidden and protected on the sides. There is also cold air induction on the dash area on both sides and below the instrument gauge. It weighs 6 lbs less than stock too.
Since the new 2018 Ascender plastic is so much narrower, you need to change the running boards to the narrower version which we call our Ascender Pro-Boards. We took it one step further by narrowing them up one more inch from the factory 2018 running boards, to be the best board for side hilling. They are constructed with specially designed extruded aluminum with built in traction teeth to keep you from slipping. No need to spend time drilling and installing all of those little screws like other brands use. The inner triangular shaped channel makes installation much easier, and it prevents snow from building up along the tunnel like a round tube would. We spent a lot of extra time to develop the best "no snow running board" on the market. This new premium design makes snow build up nearly impossible, and with built in anti-slip traction, this is the best board on the market. Using the Pro-Boards also makes the chassis more rigid and strong.
Since the new side panels are so much narrower, the stock oil tank is too wide. This is why our kit comes with our lightweight chaincase cover and oil tank kit. The chaincase cover is super light magnesium and has a added dipstick and drainplug for easy maintenance. The plastic 2 quart oil tank comes with a nice billet aluminum mounting plate.
PRE-SEASON ORDER YOURS NOW FOR ONLY $1599!! SAVE $400!!
SIMPLY PUT $300 DOWN NOW AND TAKE DELIVERY IN THE FALL!!
http://www.bd-xtreme.com/index.php?..._shop=1&id_employee=3&theme=&theme_font=font7
*If you want to run premix or have a belt drive, you can purchase the kit without the chaincase cover and oil tank.
**We also have new take off seats and gas tank combo's in black if you want to upgrade your 2012-13 model to a new style version. Look in our Garage Sale section on the website.
***We will also be offering sled wraps for them too so you can customize your machine even more
