ram, that looks good man! Are you local??
sorry it took so long but got a couple of pics for ya. took this out sunday and put 60 miles on it. worked perfectly, the underhood temps seemed better, will have to wait for some deep pow to see how much better...
I think your system looks good but working good I think not.Unless you have some type of cover over those filters you are going to be sucking warm air from under the hood.If you do put a cover over them you are going to be air starved because no air can get in unless you drill holes into bumper and ski wells and cover with a screen that lets air pass not moisture.
I would recommend going to Black Diamond and ordering a light weight cold airbox.$169.00 you can't beat the price and you get something that is proven to work.It comes complete with all the screens you need and is a true cold air system. Notice in pictures how the airbox is covered and pictures of bumper how it gets air through bumper. This is an excellent product that I will use on my next sled again.Just my opinion.
Cheers,
Dave
I just wonder about the BDX setup sucking in air through the front like that. Does it not clog when pushing through deep powder? It looks like snow would just stick to the vents. I think the theory with the pod filters is similar to the theory being used by OVS and Twisted Turbos where they mount the intake low in the belly pan. They are saying that the hot air is going to rise so vent the hood well and the hot air will exit out the top of the hood while the cold dense air settles low in the belly pan. Just a thought.
I guess the belly pan was the wrong phrase but I guess what I was saying is that he is not shielding the filter from underhood heat. The way I explained it (with hot air rising) was the way shain explained it to me when I asked him about why the filters were under the hood.
On Shains system right in front of the filter on the turbo in the ski well is a intake screen were this brute sucks from.You questioned will my BDX airbox plug up with all the screens yet say that the OVS or Twisted Turbo work but they have only one screen right in front of the turbo intake.In thery if the one and only screen in front of the turbo were to get clogged it would start sucking warm air from under the hood.Well I can assure you it doesn't because we have rode through deep powder and that Twisted Turbo never missed a beat.Also I said I had rode my sled in deep powder and also never clogged up .Only problem I had was side hilling on exhaust side on my sled in the deep and choked my exhaust which I hope to eliminate this weekend.
Just my opinion though.
What is your plan to fix this??
All I know is that sleds draw a LOT of air at WFO, so IMO, if you are pushing snow with slow ground speed using a BDX or similar intake, after a short time you will scavenge any air available under the hood which will be hotter than outside air.
I think the twisted set up or similar would be the lesser of 2 evils as the shock towers get less snow build up due to the A arms and skis shielding them.
