Yes, X2, how about a quick recap or link to this Geo oil cap mod? Sounds like another one of many note worthy innovations from our Canadian free thinker.
Just a thought on the air bubble. Wondering if it is caused by the routing of the oil supply line and motor heat. I have not had an air bubble in my supply line since the $28 upgrade. Same oil cap.
For comparison, the 550f had the air bubble problem that had many a motor meet its demise. Heat soak of the oil was the cause. Polaris came out with a bleed kit (2203889) to rectify the problem.
Ex-Flit, you may be onto the cause of a caps venting failure. Complete filling of the tank that submerses the caps check valve would have a negative affect on its design. Personally, I fill my oil tank to 3/4" below the bottom of the fill neck.
I think that was the cause of the 12 Cats going down... Until they fixed it with a sticker. lol
Dave,
So that I have this correct... after your vent mod on all of your machines... you've never seen another air bubble situation on those sleds? (sincere question).
Good Discussion BTW.
vtboonedocker I see your points, but really? Our sleds are always bucking around and the ball im sure just doesnt stay put for how the slow the reservoir empties.imho
Switchbackenvy This all makes good sense but wouldn't you think that the ball will always be bouncing around hitting the stem and venting all the time?
northstarrick In a perfect world yes. but what I believe is happening is this. oil gets in there, with moisture,ice etc. it has a very small vent hole in the cap.and the angle of the tank is on the boarded line of venting at idle anyway. if your sled is tipped to the left a little or the trailer isn't level then its not going to vent anyway. if the pump draws more then 10"water column of vacuum it will never vent until the cap is opened. I have already tested this. with a empty tank with a mity vac. I banged the tank off the work bench and shook it as hard as I could. did not open the vent. and the ball was rattling the whole time. granted this takes a lot of things in combination to cause this. but do you want to gamble with your $12,000 sled? it can happen under the right conditions. the other thing is its causing erratic oil consumption from no venting then venting then not again. if your out west pulling a long shoot at wot the cap is not venting. and its using the most oil at this throttle position. it wouldn't take long to draw a fatal vacuum. maybe all the sleds in the west going down was due to this and nothing else?
Tried to find that thread about geo's oil cap mod but couldn't find it. So with the 3 holes, it doesn't leak?
