wanted to show you guys the Trail Tank.
I am running a 2009 Dragon 800 CFI pump, wired for a float (some arent i guess), this pump is a 4 bar, 58psi pump and is the exact same specs as the 05 RMK 900s, will not work on the 06 models..
The fuel pump wiring harness is a direct fitment to the stock wiring on the 900 as well
The tank mods up very good. I had to trim a little section from the metal gaurd that is next to the brake rotor.
The MAG side of the tank fits nice, and the rubber hold down on the underneath of the steering hoop holds this side of the tank well.
the PTO side of the tank is lower, so you can either weld a bracket to the steering hoop to hold the tank down (which i might change to this summer cause i think its better) or you can use a rubber push style bracket. i got the push down bracket from Seth at trail tank...just need to drill a hole for it to mount to, but its so close to the fuel pump screw cap its hard to get it perfect.
I am using the newer IQ center console (07-09 i believe) and the contour of the tank fits the center console perfect, with no gaops.
I also got lucky and got a 2011 Pro RMK seat from the 2011 Snowest Build, and I am very greatful for the hook up on that one!!!
The OEM 900 fuel lines are too short to reach back to the pump since it since different, but its not a big issue, you can add an extension and get the fuel line adapters for cheap at your local hardware store, when i get to that point, i will show you what i did.
Also just need to drill 2 holes in the rear of the tunnel to hold the tank to the tunnel and BAM, trail tank
some pics....
