I think you need riding lessons before a turbo!![]()
I think he needs you to build a custom billet bumper that is indestructible.![]()
Now that your done coating all that stock suspension stuff red, do you want to coat my red Timbersled black for my T975?
I will need some unobtainium to make Sean proof bumper![]()
Im in....ill take 37 of them for next season, lol.
p.s. Kreg...member the emails on what we talked about...send'em when you can!!
^^^AMEN...LOL...
worst invention ever, id rather pull my skid and drivershaft in and out all day, LOL...
TBC™ Ceramic Thermal Barrier:
For most naturally aspirated and mild boost motors TBC™ is our tried and true ceramic thermal barrier coating. Swain’s TBC™ has come a long way since it started the internal engine coating revolution back in the 1970’s. Now in its 5th generation of development, Swain’s TBC™ uses Swain’s exclusive “Smart Coat” technology which allows the ceramic to expand at the same rate as the piston. TBC™ coated pistons run cooler and retain much more of their tensile strength. TBC™ protects against high temperature oxidation, eliminates hot spots, and encourages proper flame travel. The ceramic also spreads the heat evenly over the entire coated surface reducing detonation, pre-ignition and allowing the use of lower octane fuel. Less heat is conducted through the wrist pins and rods keeping the crank, bearings, oil and entire bottom end cooler.
PC-9™ Solid Film Lubricant:
In addition to power being lost through heat, power is also lost due to excessive friction. Poly Moly™ has an extremely low coefficient of friction, reduces scuffing caused by piston movement and provides back-up lubrication if your primary lubrication fails or has gone beyond its load limits.
Unlike the simple “break in” skirt coatings that are now being offered
by piston manufacturers and OEM’s, Poly Moly™ is designed to be a permanent solid film lubricant coating.
PC-9™ is Swain Tech Coatings' latest generation of piston skirt coating. PC-9™ has the same low friction properties of Poly Moly™, but PC-9™ is even tougher.
As part of Swain Tech Coatings' continued commitment to product development, PC-9™ has been engineered to meet the demands of today’s high revving, short piston skirt, and long rod motors. PC-9 works well with nickasil, chrome or iron cylinder bores.
Sean- Are you ready for your annual riding lessons yet? just kidding, we need some snow, and I need an Intercooler STILL, wtf?!
Been riding the hell out of the bikes though, plenty of snow to have fun on those for now.
haha. by riding lessons you mean demolishing derby? HAHA. then yes, yes i am.
waiting on clutch springs from SLP now, then install clutch, few more heat cycles, wash belts and slowly break in the motor...and im IN!!
belt washingand brake in are a wast of time. if you want to help give the trees some warning you are coming.
