Thank you for the reply, dktraw!! From your reply you think that the sled will start and idle even if the ecu is toast??? I have been scouring through as much info on here as I could but havn't found a difinitive call on that question!?!? Thank you again!could be a number of things. gauges not working could be bad chassis relay, fryed ecu, possibly tps setting, or broken wire in the tps wiring harness. with it running poorly the tps probably has issues. try taking the throttle bodies off and reseting that first to see if it solves the issue.
