T
Come on Roo, it was supposed to be something else than a Chopper !
By the way, I know Sledr2 (on the left) wasn't too far from that project !!!
Hahahahahahahahaha !
No kidding this is just a pic I found on google !!! Can't wait to see the first pics !
Thierry
after talking to everyone hawkers, 2-moto and explorer, and spending time on these machines I am going to build a motorcycle posistion(handle bars mounted on top of forks), 2 stroke, CVT, sled suspension single ski. got laid off from my job on return from hawkfest, will give me the time to get a good jump on this project and maybe have it on the snow before it's gone!!!!!!
HAVE:
motor= mxz 440x 92 h.p. (with primary) donated by tony sexton
chassis= steel cr250 donated by darrel aka cyclops (frame soon to be butchered beyond belief) probally just use headtube.
using banshee seat and gas tank and upper section of frame (maybe just for pattern)
triple clamp, forks= 2001 cr250 off my bike will have third triple clamp located lower, made from an aftermarket fork brace.
___________________________________________________________________________________
drivers= stock hawk donated by onewoodsrider(not using due to diamond drive) thanks alot for the help though!
secondary=stock hawk donated by onewoodsrider
track=121" donated by defboy
rear skid= have original expert off 503, will use expert design and machine lighter componets.
bought 09 diamond drive, driveshaft, drivers, brake caliper and rotor off ebay with funding from ryan,(aka poacher) thanks a bunch for the donation ryan, I beleive this will make the project. it will free a ton of space and allow better location options. big thanks to tom at alaska toy rental for the ideas.
NEED:
diamond drive secondary (06 to present) 10.4 inch. (can use pre 06 10" if can't find.) may end up buying new $384, loaded with close to right springs?
brake lever/master off A SNOWMOBILE?
laid off, don't have alot of funding, will fund as much as possible, any parts donations, deals or loner parts would be awesome,(even to just get it going) will post and help with any and all info related to project for your use not out to make money, would like to see a cross between hawk and bike!!!!!! will draw up detailed blueprint when done. I AM LIFE LONG BUDDIES WITH A MINISPRINT FRAME BUILDER HERE IN WA WHO IS WILLING TO DONATE MATERIAL AND ALL THE FINISH WELDING.
I had thought of putting a linkage on the rear suspension at the bottom of the shocks that would push the shocks from the bottom as the suspension compresses to give it a rising rate. I have a complete wilwood hydraulic brake setup that you can have if needed, came off of a '95 mxzx.
got almost everything together. have some cash comin in a couple weeks, will be able to get a clutch, finish jig and start welding. anyone know the fork spring rate of the hawks?
I dont think the spring rate for a hawk will be the ticket for you. I think you said your running cr250 forks?? The weight bias (front to back) difference from the hawk to what your building has got to be much diff.
I would get it all together and then start looking into suspension spring rates.. You have to know your starting point and without that info you may end up spending unnecessary coin.. or spinning wheels.. just a suggestion..
Cant wait to start ripping apart my Hawk, big changes are a cummin..
Thierry
is this gonna be tested soon with all the snow im hearing about in the mountains?
