How do you stop yourself?
From the madness!
http://www.youtube.com/watch?v=W8GRQHsAVjI&feature=related
What prevents the lefty lower tube from spinning inside the upper tube is just 4 flats on the lower section (like wrench flats on a rod). These 4 flats runs on needle bearings at the base of the upper fork tube and then pevents the 2 parts from spinning into each other. You also get rid of all friction from "bushings" rubbing against each other throughout the stroke. The thing though is we would probably need something like 16 inches of flats if we wanted 12 inches of stroke out of her. That would make a pretty damn long fork I think...
The upper section of the lower tube is circular & conventionnal fork mechanic is in there. So it wouldn't be thaaaaaaat bad to build. Getting it to work right might be a pain though... What scares me the most with fork parts are tolerances that these things are built off of...
I wish I had one to take apart... I've been looking for one for my XC bike frame that I build 2 years ago... Still no parts on it... Snow-Hawking is too expensive...
Do you think that there would be a balance issue with the diamond drive containing everthing on one side? Maybe throw a brick or something else high tech on the other side to balance 'er out? hahaha
TLKDPROD
Remember cheap is the Key.
-I have a "Main Goal" of 300 lbs Dry for the machine. I hope your Lefty or my Duo link idea will work on it!
Does anyone know off hand that the Hawk's (say 600/800) Rear suspension Travel is? the Front is 12"................................
