I need to get them hard anodized. Thx for the reminder. Cheer s!just nice shiny aluminum cnc is always fun to look at.
Naw I have seen the opposite- and it causes some grief and it doesn't belong there it serves zero purpose...Not necessary.
Thousands of sleds with thousands of miles over the last 6+ yrs and zero failures of the aluminum sprocket.....[emoji3061]
The aluminum sprocket has a lot of wear initially however, once the sprocket conforms to the shape of the chain..... they maintain that shape for a very long time.
The small aluminum shavings in the oil will not harm the chain, bearings, or sprockets, all those materials are much harder...[emoji4]
Sent it
1 pound of rotational weight is not even close to comparable to 1 pound of static weight.I agree with those that suggest a heavier steel gear should have been used instead of aluminum. Even though its rotating mass, its so close to the same rotational surface speed as the track, that 1 pound here over a ~600 pound sled with rider gives you about a 0.2% difference in acceleration. I believe the 1 pound saving here should be used to increase durability and decrease wear. If you want to save 1 pound, skip lunch that day or take a piss before riding.
At the track it is because the track drives the inertia of the sled. All the static mass in the sled and on the sled (rider) is imposed on the track. The rotational inertia of the motor and rotating components connected to the track is added to this static mass. The motor must accelerate it all.1 pound of rotational weight is not even close to comparable to 1 pound of static weight.
So, no gain with a belt drive over steel gears and chain?At the track it is because the track drives the inertia of the sled. All the static mass in the sled and on the sled (rider) is imposed on the track. The rotational inertia of the motor and rotating components connected to the track is added to this static mass. The motor must accelerate it all.
So a 20lb sprocket would have the same effect on power as a 20lb backpack?At the track it is because the track drives the inertia of the sled. All the static mass in the sled and on the sled (rider) is imposed on the track. The rotational inertia of the motor and rotating components connected to the track is added to this static mass. The motor must accelerate it all.
The higher you can get the belt to go up on the primary clutch, the faster the sled will go.Ya - I am just going to dump the stock cheapo gear for my son and get a steel gear- I do agree with the comments on rotational weight savings - but the lower drive gear is not the place to be focusing for the rotational weight..
I rather have the durability there- the way these kids ( or younger adults) launch their sleds these day's.
If Santa is good to him he will be sporting a TKI belt drive conversion...and gain in both rotational and static weight.
I may try to gear up a tooth or two and see if it make a difference.. with the way the sled launched last year, it could stand a tad higher gearing and gain more track speed.
Same weight and gear ratio, little to none. No gear oil saves a little but so little to not even mention it. There might be a little change in friction loads between the belt and chain but again it is little. Increasing the ratio just a little is huge however as the inertia of the sled is reduced as seen by the motor by the ratio squared. So if you went from say a 2.8 to 1 to a 3 to one for example, 3/2.5 = 1.07, however (1.07) ^2 is 1.15. So a 7% increase in ratio decreases the inertia of the sled as seen by the motor by 15 percent. This squared function occurs because the lower gear rotates 1.07 times slower and there is 1.07 times the torque available to accelerate it. 1.07 X 1.07 = 1.15 A clutching change is required to take advantage of the reduced inertia reflected to the secondary clutch.So, no gain with a belt drive over steel gears and chain?
Sent it
Not exactly but pretty close. If the diameter of the lower sprocket is about the same of the track driver and the shape of the sprocket didn't change much, then yes, if not then no. Most people don't have a clue of how things work because they don't understand the physics of the problem. They repeat what they have heard and then that is repeated many times over and a little is lost with each repeat. You may have heard the adage "1 pound of rotational mass is equal to 7 pounds of static mass". Partially true but the ratio is way off.So a 20lb sprocket would have the same effect on power as a 20lb backpack?
Don't think so.
If gearing up causes the belt to go lower on the primary, will the sled go faster or slower?
I don't have the time as I get maybe 8 total days every year. Also to effectively take advantage of a gearing change you need to change the clutching, which opens up a big can of worms. My opinion is you should gear for the speed range you care about most. In the mountains off trail that for me is about 60 mph max, as the 3" lugs start wearing excessively over that. Once you open that can you have a lot of variables to consider.Instead of all this theory about what if's, how about just actually play with gearing and see what you get. Its simple to do and is a good learning experience
I have taken your advice. I went from 2.3, 2.5, 2.6, 2.7, 2.8, 3.05, 3.22, 3.46 and finally 3.65. I’m at 3.65 gear ratio with a 174” na 800. It eats turbos in the deep. On hardpack it’s hard to overcome the sheer power of the turbo.Instead of all this theory about what if's, how about just actually play with gearing and see what you get. Its simple to do and is a good learning experience
Top speed 55?I have taken your advice. I went from 2.3, 2.5, 2.6, 2.7, 2.8, 3.05, 3.22, 3.46 and finally 3.65. I’m at 3.65 gear ratio with a 174” na 800. It eats turbos in the deep. Hard pack, not so much.
Not a lot of difference from 2.7-3.2. It really came alive at 3.30+. A total of 70 gear and clutching changes to get there. Was a long 3 years.
Loving the doubters. It’s great.
