Draw three vertical lines on primary clutch sheave with sharpie. Ride for a day (make sure RPMs are hitting peak), then look at the lines for wear. If the lines are not completely worn off (belt riding to top of primary) gear down.
Keep gearing down in 2mph increments until you are using 100% of the clutches. This will take all factors including rider weight into account when setting gear ratio. You may need to add primary weight as your peak RPMs will start to increase. So add weight after you get max shift out. Once you add weight to reduce RPMs to peak you will feel a noticeable difference in acceleration.
After the top of the clutch gets broken in it will feel like you have gone from a 4 speed trans to a 10 speed trans in your pickup. Much smoother and sled will drive away easier in heavy snow loads. Belt life will also increase.
Photo is a Polaris but same works for cat..
