A
ak
Just changed springs on the Carls 660, it has bearing, cup, washer, spring, then roller. No plates on both sides of bearing.
It should have came with one washer
I was considering the thrust bearing kit as well, but have some concerns with the increase in spring pressure and decrease in initial starting angle.
AS for the helix starting angle......if you used a 48-44F cut helix and ramp travel is 1.1".....there is a 4* spread.
So if you have a starting angle of 48 degrees.....with the shim/bearings in place, the starting angle is now 47.5 degrees. This also will have a small impact on your previous clutching recipe.
If I'm out to lunch here guys, please let me know.....but I don't think I am...?
The bearing does not alter the position of the rollers in the helix since it is positioned on the opposite end of the spring. Therefore the starting angle is not changed. If you shimmed between the spider/roller assembly and the retainer clip you could alter the helix duration for the starting angle.
Maybe I'm wrong, but that's the way I see it.
Can you provide an example of what clutching components were utlized before and after the kit?
All models, track lengths, gearing, altitude etc. are all taken into consideration so no one will answer that with one simple answer.
Does anyone have a trick to getting the helix bolts out? I have broken a couple bits now, tried warming the aluminum slightly, tapping screw head with a punch. Three of them will not come loose, thanks for any help.
