considering turbo v3
I use the stock, you can tie the oil cable out of the way, or remove it from the block.
when you guys use those 1/8th nipples (from turbo performance) do you use the little o ring or just use thread sealer?
also is it ok to get fuel for power jets from the opposite bowl the best way for me to route my lines is to cross them from one side to the other
we use loctite on the male adt.
yes you can route your fuel that way. just makes it harder to trouble shoot the carbs if something goes wrong.
what loctite?
I was using 567 which is just a thread sealer not a locker, in conjunction with the little o-ring thing you guys send with the nipples,
I am kind of fighting with the o-rings but I dont think they will be a problem in the end
honestly, a properly tapped hole of brass into alum shouldnt require loctite.. but a thread sealer would be a good idea just because you can.. i think the set we installed didnt have anything on them.. and no leaking issues.
I am just gonna leave them the way they are it is kind of hard to tell how tight they are with those o rings on there and then if they leak or fall out figure something out at that point
I dont use the little oringy thing either, they are too soft for a butt fit.
would work correct if we had a taper seat to contain them from being extruded.
Gus
we just cut the oil cable off then strip back the outside sheth say 3/8 and put a rubber cap on has worked well for many years.
I removed the cable from the junction box then cut off the cable housing at the box and siliconed over the hole
gonna take out those o rings
how much vacuum do these motors make, I need to know for my bov
I got all my stuff hopefully have this machine running soon, I ended up going with turbosmart stuff instead of the tial just cause it was easy to get
starting to get places, hopefully be pulling the rope by this weekend
next steps are to weld on wastegate and bov, then run all lines and wiring, its getting close, we are going to revy November 11th, I should have been done sooner but I waited so long for my v band flanges and clamps that it set me way back.
any one have pictures of remote powerjet adjusters, I messaged twister but no return.
also should I run coolant through my turbo?
Yes, you will wanna run coolant through your turbo if you can. I ran mine out of the top of the head(old heated carbs line) through the center section and back to the coolant tank. If you don't, it called coking, its when you shut the motor down and the turbo becomes a heat sink cooking your oil into carbon mess.
Mine is also straight piped out the bottom(original exit). Its still very loud. You will find that the turbo doesn't muffle the exhaust as much as you would think.
remotes
Here is a pic of my dash mounted remotes.
how do those adjusters attach to the power jets? wat makes them turn
thats a nice spot for your gauges how are they to look at?
Turbo setup is looking great. Where are you guy's getting remote adjusters? Would like to get a set for my second set of powerjets.
remotes
The remotes are actually flexible drive shafts from mcmaster carr.
http://www.mcmaster.com/#flexible-drive-shafts/=erh6k8
I have the steel with female end and panel mount in .187" diameter and then pick your length. The 1/4" female end goes over your power jet and is set with an allen screw. The lengths were a little long for my application so i actually cut the cable down and tied them together with a small clamp. They work great and i have had zero problems. I went to the local hardware store for my knobs.
The gauges work great. I clock the boost gauge so my desired boost is at 12 0'clock. If i did it again i would go with 2" gauges.
